How to hide control bar
  • If I am not doing something wrong, this does just minimize the control bar and does not completely remove it, so that it can't be reopened.
    I do not want to exclude the whole vtourskin.xml, if this would be an option, because I am using the littleplanetintro. I've also uncommented the
    skin_showskin();
    in the skin_setup_littleplanetintro action, but this leads to the same result (the control bar is minimized and can be reopened).
    Any help is very much appreciated.
    in the tour.xml in the 'startup' <action> add this line:
    skin_hideskin('instant');
    Hi I found controlerbar in vtourskin.xml . I only want it to appear on desktop and hidden on mobile and tablet. I added devices="desktop" in layername but it doesn't work. Can you help me? thanks you very much.
  • tour.xml
    <action autorun="onstart">
    tour.html
    Edited 4 times, last by puxiao: optimize code (January 6, 2026 at 7:15 AM).
