problem with hotspot position after upgrading from 1.18.3 to 1.20.6
  • Recently we upgrade from version 1.18.3 to 1.20.6 and rec-creating some virtual tours we noticed some problems with hotspot positioning.
    ath and atv values are exactly the same but hotspot seems rotated of some degrees (180 degrees tipically).
    I tried to compare main xml configuration files generated with each version and I saw that new version adds prealign option to images while older version does not.
    Removing prealign option manually doesn't solve my problem.
    How can we solve the problems?
    It seems that new version need some tweaking but we don't know which files must be modified.
    We use standards files schema for generate vt (like the one availiable in the samples) adding very basic options (watermarks and some speed regulation)
    Thank you in advance
