It didn't help The ripple doesn't turn off
you must add this action after including callout.xml file to override
Hello! I understand that calaut hotspots do not work in vr mode. But how do I make sure that after exiting vr mode, they are displayed again? They are not visible after exiting VR. Example: https://panorama07.com/tours/panorama/
When exiting VR mode you must call onloaded event for each callout hotspots
Could you write in more detail exactly how to do this? Thanks!
I need to test this plugin using Panotour Pro 2.5.4 with KRPano 1.19-pr16 (but using 1.21.2)
But I don't find the download link to download for the test. I am very impressed and need to purchase but first I want to test.
Thank you in advance.
I just started working with KRpano and this plugin. When using the "click action" callout code, how do I link that to a different scene? I need the hotspot to take me to a different room but I still need the callout text.
hotspot name="hs8" ath="210" atv="0" style="callout" onclick="showlog();trace('hotspot ',name,' has been clicked')"
title="Click action"
content="Onclick action will be called by the spot and text."/>
No demo version for Panotour.
To load a scene use the loadscene action : https://krpano.com/docu/actions/#loadscene
Jerome,
Is there any way to add website links to the callout content=""/>
Of course, like for any textfields
eg : [a href='https://www.360images.fr']Visit my website[/a]
I purchased this plugin and set the license key provided at the time of purchase, but the watermark that says "CALLOUT HOTSPOTS PLUGIN" did not disappear. I was under the impression that the watermark would disappear once the license key was set. Is it not supposed to disappear? I have entered the license key exactly as indicated in the example provided in the email.
Jerome,
Thanks for the example on how to set up a link. It works great. Is it possible to open that link in a new (separate) window?
<hotspot name="hs11web" ath="300" atv="-10" style="callout" text_bg="true" callout_bg_color="0x00688f" callout_bg_alpha="0.6" callout_bg_border="1" text_width="auto" text_padding="10" text_x="0"
content="[a href='https://www.ciudadcubica.com/' target='blanc' style='color:rgb(255,255,255);text-decoration:none']Ir al sitio web[/a]"
Hello!
Got the same issue.
Added the action as was advised in tour.xml
<include url="plugins/callout.xml"/>
<action name="pulse"></action>
but there is still pulsation.
Link: https://aragent.eu/virtual-tours/Vana-Joala/tour.html
Please advise what to do.
Thanx
<action name="pulse">set(layer[%1].alpha,0);</action>
should work
Does your plugin support drawing a straight line between two points? For example, drawing a line between coordinates (0,0) and (0,20), with a text label in the middle.
Thank you!
jeromebg,
No matter how much I have tried, I can't get a transparency in the background of the title:
title_backgroundalpha="0.5"
title_background_bg_alpha="0.5".
I want to achieve it as it is achieved in the content:
callout_bg_color="0x00688f" callout_bg_alpha="0.5"
Is this possible?
This is not implemented.
I will soon rewrite this plugin from scratch with the new reactive API.
ok, thanks
The hotspot design you are showing is not possible with callout plugin, krpano or panotour version.
