How to make Hotspots behind the Depthmap Model NOT clickable?
  • Hi Calin
    Thanks for your tip.
    If I understand you right, then you would cover every wall, witch has hotspots behind it, with another hotspot?
    That means alot of manual work if you have many rooms *mellow*
    Is there no way to use the Depthmodel to prevent clickable hotspots behind walls?
    Edit 1:
    One other problem occured:
    When the mousepointer is over a hotspot then draging for looking around is not possible anymore.
    Is there a way to keep the dragingevent when the mousepointer is over a hotspot?
    Edit 2: Got it: capture="false" does the trick *smile*
    Kind regards
    Alain
    Edited 2 times, last by Alain (November 3, 2020 at 11:40 AM).
