everpano 3D 1.3.0
Hello everyone,
I am fairly new to everpano 3D.
After doing my tour and I have uploaded the files to the web and viewed it, I came up with error.
can you verify that the model.obj is correctly uploaded to it's folder ?
can you share the link -
Quote
can you share the linkHello Mr. Jordi,
The model.obj is in it's correct folder.
Here is the link: https://www.finehomeint.com/panorama360/OF981029/index.html -
yes seems to be there, but if you try to access the file directly
https://www.finehomeint.com/panorama360/OF…del3d/model.obj
you get that error from your server :
The page cannot be displayed because an internal server error has occurred
So this seems to be some internal configuration of the files on your server.
I would try check the file permission, and validate you have assigned read public permissions.
Quote
Hello Mr. Jordi,
I check my file attribute, I guess, there is nothing wrong here.
assign some values, at least 544 instead of xxx
BTW - I already implemented a workaround to force the model.obj file to have those basic read permissions (544) regardless the user OS settings
there's a new release everpano 3D 1.3.4 with some new features :
- multiresolution in the render
- new navigator plugin
- bundled with krpano 1.20.10
- some bug fixes
take a look at the post for more info
kind regards
Hi, thanks again for your update i was paciently waiting too for the "movement" :)
I wanted to ask you is it possible to have the option to use "resized" or full version of the jpeg? because is harder for me now to match the images because quality is to low, understand the reason is for speed, but i still would like to have the option to change to full preview isntead of the low quality preview.
Thank you!
Regards
Sebastian -
there's a new release 1.3.3 which fixes some small issues :
- Path to preview images on the render folder
there was an issue here that the preview path was not correctly set so the preview from the scene was not loaded
- Small fixes in NavigatorPlugin
not found scene was not working
- Issue with blank spaces in the project path, if the name had more than one blank space it was causing an issue
if you had a project with multiple blank spaces in the path the texture file where not generated
now you can have those blank spaces if you like
- Removed the fovmax limitation to the panos so you can zoom more and improve the location of references
there was a fov limitation so you could not get close to details which could lead to a bad reference generation
You can download this new release from downloads page here
I am using 1.5 version i got same texture issue in it
i dnt know what is problem with everpano plugins. not working properly. Even jordi reply on post. This is not proffesional behaviour.
Regards
