Dear all,
I want to kindly ask about adding Radar plugin into my project on my map in side menu.
I added the plug-in but i couldn't find "radar.swf".
If you do me a fever and help me ASAP, i will appreciate it.
Best regards
Mohammad
Question : How can i use radar ?
you need the radar.js .. swf is flash and not used anymore(!)
Find the plugins in your plugin folder.have a look in the krpano download for the Winecellar demo tour example.. i think that is quite clear.
viewer/examples/demotour-winecellarFind more info here as well:
https://krpano.com/plugins/radar/#topBest is to show us your example online, then it is easier to help.
Hope it helps,
Tuur -
thanks for your answer dear friend so dont i need js and swf files ?
