Hello,
I am new here and I want to thank you all for the help I already got
by reading older posts on this forum, they’ve already helped me to
go quite far building my first pano-tour. I however have a problem
that apparently hasn’t been posted, also I’ve read quite a few
posts talking about background sound problems.
1/ I want to play a background music and I used the example:
“Background Sound” on krpano.com. Sadly, I get the following
error in the VTour Editor: “ERROR: Soundinterface Load Error:
Loading failed”. The config for the VTour Editor is: “krpano
1.20.10 and HTML5/Desktop – Chrome 32.0 – WebGL” and it all
runs on Xubuntu. However when I run the same tour thanks to the
tour_testingserver.exe on Windows 7 in Firefox Mozilla, no problem,
the music plays after I click on the tour. Conclusion: the error
message doesn’t come from a mistake in the coding, but is it a bug,
an incompatibility? Or should I add something to my xml file?
Also why “Chrome 32.0” does it mean Chrome 32 bit? That would be
strange because I have a 64 bit Xubuntu and installed on it Chrome 64
bit, and I believe that I have downloaded the 64 bit Linux version of
krpano.
2/ I also noticed that on the VTour Editor, I don’t have a “full
screen” button on the display panel (I have to click right on the
screen and then choose “full screen”, while with the
tour_testingserver.exe, I have a “full screen” button on the
display panel. Is it also a compatibility issue with Chrome?
Note: I have checked that I have the latest version of Chrome
installed.
Per advance thanks for your help!
Emmanuel
p { margin-bottom: 0.25cm; line-height: 115%; background: transparent }a:link { color: #000080; so-language: zxx; text-decoration: underline }
