Hello Klaus and community,
I'm implementing a new structure for my krpano tours and need some help! This is the new way I'm structuring tours on my site :
SKIN URL https://mydomain.com/skin/ (Skin folder: krpano .js/.swf files and xml's)
TOUR URL https://client.mydomain.com/ (Subdomain linked to a folder with tour files: tour.xml / panorama tiles)
This allows to use an A record to mirror tour.domain.com into client's website subdomain (360.clientdomain.com) and also have a global skin which can be easily updated for all my tours.
I already set the embedding code at https://tour.mydomain.com/index.html to link files from https://mydomain.com/skin/ with the basic embedpano functionality as:
<body>
<script src="https://mydomain.com/skin/skin/tour.js"></script>
<div id="pano" style="width:100%;height:100%;">
<noscript><table style="width:100%;height:100%;"><tr style="vertical-align:middle;"><td><div style="text-align:center;">ERROR:<br/><br/>Javascript not activated<br/><br/></div></td></tr></table></noscript>
<script>embedpano({swf:"https://mydomain.com/skin/skin/tour.swf", xml:"tour.xml", target:"pano", html5:"always", mobilescale:1.0, passQueryParameters:true, bgcolor:"#000000"});</script>
</div>
</body>
This method loads the krpano SWF/JS files but doesn't get to load skin.xml as I get the following message:
FATAL ERROR:
https://mydomain.com/skin/skin.xml - loading failed! (0)
This skin.xml file is called internally from tour.xml by an include element (<include url="%VIEWER%/skin.xml"/>). As tour.js path already was declared I'd expect it to load (it does load directly at URL https://mydomain.com/skin/skin.xml) so I'm confused here.
I tried different placeholders:
<include url="%SWFPATH%/skin.xml"/>
<include url="%ROOT%/skin.xml"/>
None of them is working. So have you had this kind of integration before, Klaus, what do you think could be done here?
Best
Luis ![]()
