Hey there,
it's me with a strange problem again
I created hotspots as horizontal and vertical helper lines that you can move around.
See: Example
Those lines should only be 1 pixel wide, always be the whole size of the screen and be always on the same position when zooming.
So far that all works as intended.
However: When you zooming in, the lines disappear - depending on the view position.
So when you zoom in at the image center (where the lines cross) you can zoom in all the way.
When you go to the left/right/top/bottom however the line are gone at some level.
So more you move out of the center so further you have zoom out to see the lines.
Can someone help me with this problem?
I first thougth about playing with the zoom and distorted attributes but using those I can't get 1 pixel lines working as you need some scale than.
Thanks for any advice!
