Hi, I add distorted video with controls and it is working under 1.20.11.
The same code for distorted video with controls but under 1.21 is not visible.
Where should I search for the reason?
Can you provide a bare bone to see how you organize things?
Or share code perhaps..
seems to work just fine.
https://www.virtualtuur.com/krpano/121/bar…eo/1/index.html
xml:
https://www.virtualtuur.com/krpano/121/bar…ideo/1/tour.xml
perhaps you have a more complex or different set up? 3D? VR?
Hope it helps,
Hi Tuur,
I just drop pano to Make tours in Krpano tools.
Add the hotspot code and 1.20.11 works:
https://www.virtualczech.cz/video12011/tour.html
I make the same with Krapano tools 1.21 and copy paste the same hotspot code and no video under 1.21:
https://www.virtualczech.cz/video121/tour.html
Hi Matyhr,
I see an error:
ERROR: hotspot[hs_video] - loading of './plugins/videoplayer.swf' failed!
try videoplayer.js
also check the full path.
Hope it helps,
Tuur,
I used your code and video is working in 1.21.
If I add renderer="css3d" and html5controls="true" the video is gone.
But I need controls in video......
It seems that video is working only with renderer="webgl" and controls is not working.
If I set renderer="css3d" nad htmlcontrols="true" - video is gone.
But with the same renderer and htmlcontrols both video and controls are working under 1.20.11 as is in my example.
So, how to make controls working in video under 1.21 ???
I can't help you with that, I just never use that.
I always make my own custom controls when needed.
But strange they don't show.
Not sure why.
I hope Klaus will reply this post.
I used to use videohtml5 controls until 1.21 with no problems.
Thanks anyway Tuur
do you have a link to the example?
For using the html5 controls, the setting renderer="css3d" is required - but there is indeed a bug in the current version that causes an invisible video, when the renderer setting gets changed dynamically in some cases (is already fixed for the next release).
Ah!
As mentioned here:
https://krpano.com/forum/wbb/inde…90274#post90274
I don't find anything in the release notes related to this.
krpano.com - Documentation - Release Notes
Has this been resolved in 1.21.1, or shall it be in 1.22 ?
Currently using 1.21.1 and video still not showing when using css3d as the renderer.
gr,
Kristof
Hi, right - that's not fixed in 1.21.1, but it is in 1.22.
