been at this for a while now but no matter what I try, my measurements are way off.
I have set the camera height accordingly and have also [repeatedly] realigned my panoramas.
Images were shot on a RICOH Theta X. (Maybe an issue with the Theta X's focal length settings?)
I UPLOADED A LIVE EXAMPLE TO christianschubert.tech/everpano for testing (just one pano for simplicity sake). The original pano image used can be found at christianschubert.tech/everpano/04.jpg:
In preparation for this live example I aligned the pano accordingly and determined the height of the camera by setting the width of the entrance door (the closed door) to 90cm. everpano determined the camera height to be 159.098, which is way too low. (However, setting the camera to its real height doesn't correct the measurements either...)
If you measure the width of the entrance door in my live example, the viewer will spit out approx. 56.5cm (a farcry from the actual 90cm).
How can I fix this?
Do I need to reshoot the pictures, and if yes, what do I have to watch out for?
Is it best to manually adjust some values in one of the xml/json files?
Thank you for your help,
C.
