when i create a polyline using ath and atv of 3 points, and at point no3 i add another hotspot using image, so when it not too far away from each other they attached to each other,
however when i drag the image hotspot away the polyline being weird, i check the ath and atv of polyline last point and the image hotspot, they both fine, but as you can see it not working
if anyone have any idea why please tell me, tks u very much and sorry for my poor english
Polyline hotspot disapeared when points being too far from each other
- Official Post
Do you have more information or an example?
https://drive.google.com/file/d/18n-uG8…iew?usp=sharing
please check video in this google drive -
- Official Post
That could be a technical limitations, drawing thick 2d-lines in 3d-space with WebGL is unfortunately quite complex and there are some edge cases at extreme projections...
You could try if enabling this settings helps:
https://krpano.com/docu/xml/#hotspot.borderwidth3dOr otherwise to add more points in between...
