i got an issue in everpano when i export the model there is no texture in it and its seems grey
issue in texture exporting in everpano
When this happened to me I solved it by using a file name, as simplified as possible. Do not use hyphens or underscores, nor capital letters, especially names that are too long. I hope that helps
i have the same issue but still couldn't find the solution. I have tried various methods and fixes but I couldn't succeed. I did the same as you mentioned above, but could not succeed. Any help?
Make sure that the folder where the file comes from does not have a name that is too long and does not have spaces. If the texture was generated in .png, change it to .jpg
ramirox3 Thank you for your reply i tried it but could not succeed I have attached the path ss and the texture file it is generated.
