Hello everyone,
I'm encountering an issue while attempting to modify the button layout and size of the control bar in my krpano tour. Recently, I removed some buttons that I didn't need, and now I have gaps in the bar that I'd like to adjust for a more aesthetically pleasing interface.
I'm trying to make these modifications in the vtourskin.xml file, specifically in the following section:
<layer name="skin_control_bar" type="container" align="bottom" width="get:skin_settings.controlbar_width" height="calc:skin_settings.controlbar_height" x="0" y="get:skin_settings.controlbar_offset" onloaded="skin_calc_opened_closed();" zorder="3">
<layer name="skin_control_bar_buttons" type="container" align="leftbottom" width="100%" height="get:skin_settings.controlbar_height">
<!--<layer name="skin_btn_prev" style="skin_base|skin_glow" crop="0|64|64|64" align="left" x="5" y="0" scale="0.5" alpha="0.5" onclick="if(skin_settings.thumbs_loop, skin_nextscene_loop(-1), skin_nextscene(-1) );" />
<layer name="skin_btn_thumbs" style="skin_base|skin_glow" crop="0|128|64|64" align="left" x="50" y="0" scale="0.5" ondown="skin_showmap(false); skin_showthumbs();" />
<layer name="skin_btn_map" style="skin_base|skin_glow" crop="64|128|64|64" align="left" x="90" y="0" scale="0.5" ondown="skin_showthumbs(false); skin_showmap();" visible="false" />-->
<layer name="skin_btn_navi" type="container" align="center" x="0" width="240" height="32">
<layer name="skin_btn_left" style="skin_base|skin_glow" crop="0|192|64|64" align="center" x="-100" y="0" scale="0.5" ondown="set(hlookat_moveforce,-1);" onup="set(hlookat_moveforce,0);" />
<layer name="skin_btn_right" style="skin_base|skin_glow" crop="64|192|64|64" align="center" x="-60" y="0" scale="0.5" ondown="set(hlookat_moveforce,+1);" onup="set(hlookat_moveforce,0);" />
<layer name="skin_btn_up" style="skin_base|skin_glow" crop="0|256|64|64" align="center" x="-20" y="0" scale="0.5" ondown="set(vlookat_moveforce,-1);" onup="set(vlookat_moveforce,0);" />
<layer name="skin_btn_down" style="skin_base|skin_glow" crop="64|256|64|64" align="center" x="+20" y="0" scale="0.5" ondown="set(vlookat_moveforce,+1);" onup="set(vlookat_moveforce,0);" />
<layer name="skin_btn_in" style="skin_base|skin_glow" crop="0|320|64|64" align="center" x="+60" y="0" scale="0.5" ondown="set(fov_moveforce,-1);" onup="set(fov_moveforce,0);" />
<layer name="skin_btn_out" style="skin_base|skin_glow" crop="64|320|64|64" align="center" x="+100" y="0" scale="0.5" ondown="set(fov_moveforce,+1);" onup="set(fov_moveforce,0);" />
</layer>
<layer name="skin_btn_gyro" style="skin_base|skin_glow" crop="0|384|64|64" align="center" x="+140" y="0" scale="0.5" onclick="switch(plugin[skin_gyro].enabled); if(plugin[skin_gyro].enabled, skin_showmap(false));" visible="true" devices="html5" />
<layer name="skin_btn_vr" style="skin_base|skin_glow" crop="0|0|80|64" align="center" x="+146" y="0" scale="0.5" onclick="webvr.enterVR();" visible="false" />
<layer name="skin_btn_fs" style="skin_base|skin_glow" crop="0|576|64|64" align="right" x="90" y="0" scale="0.5" onclick="switch(fullscreen);" devices="fullscreensupport" />
<layer name="skin_btn_hide" style="skin_base|skin_glow" crop="0|448|64|64" align="right" x="50" y="0" scale="0.5" onclick="skin_hideskin()" />
<layer name="skin_btn_show" type="container" bgcapture="true" align="bottom" width="100%" height="get:skin_settings.controlbar_height" y="calc:skin_settings.controlbar_height - skin_settings.controlbar_offset_closed" onclick="skin_showskin()" onhover="tween(alpha,1.0);" onout="tween(alpha,0.25);" ondown.touch="onhover();" onup.touch="onout();" visible="false" capture="false" alpha="0.0">
<layer name="skin_btn_show_icon" style="skin_base" crop="64|448|64|64" scale="0.5" align="bottom" y="2" enabled="false" />
</layer>
<!--<layer name="skin_btn_next" style="skin_base|skin_glow" crop="64|64|64|64" align="right" x="5" y="0" scale="0.5" alpha="0.5" onclick="if(skin_settings.thumbs_loop, skin_nextscene_loop(+1), skin_nextscene(+1) );" /> -->
</layer>
</layer>
I've attempted to adjust values in this section, but I'm not achieving the desired result. Could someone provide guidance on how to correctly modify the button layout and control bar size?
I appreciate any help or suggestions you can offer.
Thank you!
