Hi, lately with a project I'm getting the following error: "webgl context lost", it has never happened to me even with larger projects. Any ideas?
Thanks!
Thanks!
a WebGL context loss happens by the Browser (the krpano Tools app is just a Chrome-based Browser) runs out of GPU resources for some reason...
Maybe check your system settings or other applications what that happens...
Are you using a laptop with dedicated graphics card?
I think this error can happen when the device switches between graphic cards while the app is running.
If so you may declare the krpano app to always use the dedicated card only.
Thanks for your answer s-maier and klaus, maybe I'm working using too many resources at the same time, actually it doesn't always happen.
Greets
Fdo
The solution was upgrading GPU driver
