Hi everybody
operator += seems not working properly when the initial var is an empty string or if the string contains only white spaces. Is it normal ?
krpano version 1.21 is used.
have a good day.
Hi everybody
have a good day.
I think += is javascript. i don't see it mentioned in the docs as krpano compatible operator.
krpano.com - Documentation - Actions / Scripting Reference
Autorun = true also doesn't look familiar to me.
Strange example btw..
Tuur![]()
Hi Tuur
Thanks for your answer. To remove some strangeness for my question, this is extracted from KRPANO doc...
Variable assignments
variable=expression;
With variable assignments new variables can be created or the value of exiting variables be changed.
The expression can be either a simple value or another variable or a more complex expression.
These variable assigment operatos are available:
= - just set/copy the value.
+= - add the value.
-= - subtract the value.
*= - multiple the variable with the given value.
/= - divide the variable by the given value.
Display More
and this one extracted from release notes for version 1.21, but OK, not in "official" documentation
New: Support also <action> autorun="true" (same as autorun="onstart").
New: deprecatedwarnings - show a warning when using old deprecated actions.
according to the doc , the real problem is rather the unexpected behavior of += operator for strings...
Last point, i am sorry for my bad english. (i am French...)
the unexpected leading 0 in this case (or 'unintended String to Number conversion') is a known issue and already fixed for the next release (1.22).
Oh..
I missed both totally.. haha.
Where did you find those += operator info?
Tuur![]()
thanks Klaus and Tuur
Ah!
Merci, danke
Tuur![]()
