sorry i can't send the tour,
but i tested it now with the krpano tooltip example, there i don't have these issues
so it is probably something with my code (lots of custom stuff) ... will check that on my side.
tooltips example with clickngo
here empty tour ))))
example fixed, srry ..
@lr ... i found out the issues i had were related to my specific setup
my onover/out events get set up in the hotspots onloaded event and that interfered with hovering
fixed that now on my side.
Great, so everything works?
Updated the plugin (updated 19.05.2024 rev.936):
- fixes false positives when clicking for a long time
File link: uhta3d_clickAndGo.zip (19.05.2024 rev.936)
Updated the plugin (20.05.2024 rev.013):
- fix double-click and extra offset
- fix click on other hotspots
File link: 20.05.2024-013.zip (20.05.2024 rev.013)
the link does not work
Fixed
I hadn't tried double clicking, I just tried it with this latest update and this is what happens
Can you give a link to this tour that works, for verification?
Apologies. Apparently it was due to not refreshing the browser. I've tried it several times, locally and online and I don't see that problem anymore.
Check the plugin version in your browser console to ensure it is up to date.
Using the GArrows plug-in and the Click&Go plug-in together creates a conflict.
When you click on a hotspot, the two plug-ins work together, making two moves.
In this case, you can modify it in the setting of the GArrows plug-in as follows.
Floatingarrow_sens=" You can find this part and delete it.
This will only allow the Click&Go plug-in to operate when moving.
I like the Click & Go plug-in more comfortable.
