sorry i can't send the tour,
but i tested it now with the krpano tooltip example, there i don't have these issues ![]()
so it is probably something with my code (lots of custom stuff) ... will check that on my side.
tooltips example with clickngo
here empty tour ))))
example fixed, srry ..
@lr ... i found out the issues i had were related to my specific setup
my onover/out events get set up in the hotspots onloaded event and that interfered with hovering
fixed that now on my side. ![]()
Great, so everything works?
Updated the plugin (updated 19.05.2024 rev.936):
- fixes false positives when clicking for a long time
File link: uhta3d_clickAndGo.zip (19.05.2024 rev.936)
Updated the plugin (20.05.2024 rev.013):
- fix double-click and extra offset
- fix click on other hotspots
File link: 20.05.2024-013.zip (20.05.2024 rev.013)
the link does not work
Fixed
I hadn't tried double clicking, I just tried it with this latest update and this is what happens
Can you give a link to this tour that works, for verification?
Apologies. Apparently it was due to not refreshing the browser. I've tried it several times, locally and online and I don't see that problem anymore.
Check the plugin version in your browser console to ensure it is up to date.
Using the GArrows plug-in and the Click&Go plug-in together creates a conflict.
When you click on a hotspot, the two plug-ins work together, making two moves.
In this case, you can modify it in the setting of the GArrows plug-in as follows.
Floatingarrow_sens=" You can find this part and delete it.
This will only allow the Click&Go plug-in to operate when moving.
I like the Click & Go plug-in more comfortable.
