Hi! I have a doubt regarding the webvr plugin in devices that have controllers, such Meta Quest. I'd like to know if is possible to force the crosshair to be visible on such devices.
Thanks.
Thanks.
QuoteHi! I have a doubt regarding the webvr plugin in devices that have controllers, such Meta Quest. I'd like to know if it is possible to force the crosshair to be visible on such devices.
theoretically yes, only with hotspot. And for what purpose if controllers are used on the Quest instead of crosshairs, which is what is used for mobile VR?
Hello! Thanks for you reply. Actually I'm not using controllers. But I'd like to set the crosshair to be aways visible like on mobile, is that possible?
As far as I remember in the quest, if you do not use the controller, the dot automatically appears.Although I could be wrong
if you disconnect the controllers it will use the cross
I believe it is this one
krpano.com - Plugins - WebVR
