Creating and customizing callouts
Nice!
Like the angle thing!
I was looking for the line width and color.. is that already there?Tuur
Hello Tuur!
You need to click the red dot, it appears when you hover the cursor, and select a fill - adjust the color.
Each element (shape, lines, text block) are layersthe width of the lines in this case is the height
Hold space bar and move around in the panorama to create funny pathes and test your devices performance
On a PC, these points are created locally in the keep="false" scene. those. Each time the scene is loaded they are created anew.
I also created many points and up to 100 units the switching was almost imperceptible. -
Hi, this plugin is designed to create text callouts without images.
