Help with Adding Hotspots to Compare Panos Example in KRPano
  • I’m using the latest example of Compare Panos on KRPano (https://krpano.com/releases/1.21/examples/#compare-panos), and I’m trying to add hotspots to both the before and after scenes separately. Since they are two different scenes, I thought this would be straightforward, but for some reason, the hotspots are not showing up. Everything related to the file paths is correct, but the hotspots just won’t work.
    Has anyone encountered this issue or have any suggestions on how to fix it?
    Thanks in advance!
  • Hello
    Is there any tricks for this trouble ? I'm using compare pano, and hotspots still won’t work.
    thanks
    Nicolas CARRY
    Ingénieur d'étude : Traitement numérique
    SIG, modélisation et développement en exploration virtuelle
    UMR 6249 Chrono-environnement
    Département de Géosciences de Besançon
    Université de Franche-Comté
  • One solution is to use includexml with hotspots in a separate xml file for example :
  • Thank you
    it's working well
    Nicolas CARRY
