Help with Adding Hotspots to Compare Panos Example in KRPano
  • I’m using the latest example of Compare Panos on KRPano (https://krpano.com/releases/1.21/examples/#compare-panos), and I’m trying to add hotspots to both the before and after scenes separately. Since they are two different scenes, I thought this would be straightforward, but for some reason, the hotspots are not showing up. Everything related to the file paths is correct, but the hotspots just won’t work.
    Has anyone encountered this issue or have any suggestions on how to fix it?
    Thanks in advance!
