[NEW] Spatial Sound 4 krpano plugin / enable Ambisonic TBE audio playback
  • The spatialSound4krpano plugin allows the playback of monoscopic and stereoscopic 360 degree panoramic video files with integrated spatial audio tracks to create enhanced immersive experiences in krpano.
    Following formats are supported:
    • AmbiX 1st order
    • AmbiX 2nd order
    • Facebook TBE 6 (6 channels hybrid higher order ambisonic)
    • Facebook TBE 6.2 (6 channels ambisonic plus headlocked stereo)
    • Facebook TBE 8 (8 channels hybrid higher order ambisonic)
    • Facebook TBE 8.2 (8 channels ambisonic plus headlocked stereo)
    • Ambix 9.2 (ambiX 2nd order plus a stereo track)
    FOR MORE INFORMATION PLEASE VISIT
    Edited 3 times, last by VRME (October 1, 2025 at 2:20 PM).
    yes, the plugin is intended to work together with the built-in krpano videoplayer “videoplayer.js” as a audio transform module. All you have to do is tell the plugin which video it should use via the attribute “videoname”:
    The plugin gets the audio on DOM level and should always be synchronized with the video if you do not perform any additional heavy calculations in the “onviewchange” event, see note in the krpano documentation.
    You can also determine from which deltas soundupdates are calculated and which movements (yaw, pitch, camroll) should be taken into account. To test the plugin with your spatial footage you can use this demo template: https://vrme.eu/spatialsound4krpano/spatialsound4krpano.zip
    regards
    Edited 4 times, last by VRME (November 10, 2024 at 2:43 PM).
    sorry I don't have any other footage available at the moment that would be more suitable for you
    The demo is a short excerpt from a vr-theater with slightly edited/amplified audio. Please download the demo folder and insert your own spatial videos for testing, you just have to replace the file "2048_ambisonic.mp4"
    thank you!
  • Dear VRME,
    Thanks a lot for the Spatial Sound viewer.
    I was testing the example in my website by replacing the file "2048_ambisonic.mp4
    SpatialSound4krpano Plugin Example
    I want to ask you where do I change the initial angle of the viewer, because it doesn't start at the center of the equirectangular video but approx 110 degrees to the left. Or I am doing wrong and this angle is actually the front of the video and the ambisonics and I should rotate both video and audio to make it sound and view properly?
    Thanks in advance, Best, Emilio.
    There is no option to set the start angle of the audio. The plugin uses the current hlookat, vlookat, and camroll values of the krpano player and should always be synchronized with the viewing direction. To change the viewing direction, you can set the vlookat value, see <view.vlookat>
    You will probably need to edit the audio and video tracks in an editing program so that the directions match.
    regards
