Last time with (the excellent) 1.21 update it took many days work to get our existing code to work again. The issue was mostly syntax changes and older functions that had been replaced or renamed.
This (also excellent) 1.22 update is also causing quite a number of malfunctions. It would be really helpful Klaus if you could point out where to start looking for changes that need to be made to our existing code. This is the current version using 1.21.2 With the new 1.22 version as you can see there seems to be a lot of work to be done to get it functioning as before.
I imagine the indications of what needs to be changed are somewhere in the release notes but I would really appreciate a few quick tips as to what the most fundamental changes are.
This is what I can see at the moment:-
WARNING: There is already a blocking lookto(), the current call will be skipped!
