Klaus,
I upgraded our license, downloaded v1.22, registered, generated a new viewer .js file and updated plugins.
Now it seems like KRPano is behaving as if “Allow loading only xml and plugin files from the same domain” had been checked when generating a viewer.
I trashed all previous versions of KRPanoTools and downloaded a fresh version of 1.22. Using Protect Tool to first Restore Defaults and then generate a new viewer, the same results are returned; Loading a cross domain xml file results in External Access Denied for cross (sub)domain xml loading.
Replacing the viewer with the previous version 1.21.1 results in everything operating just fine.
I've repeated this loop a few times, getting the same results. Defining insanity...
Is there a way to completely clear out any and all caches that might hold KRPano info when generating a viewer?
Any idea on this one?
Illustrating the loading error.
Showing that the URL involved in the error above is directly accessible.
KRPanoTolls Protect Settings shows the settings used to generate a viewer.
