I found anorther thing though ...
Will tackle that later
i find the light positioning diffcult...
is it possible to add moving / rotation handles like for the models?
Not sure, good idea perhaps!
I thought about making the steps on the sliders for a, t & r's a bit bigger. You can click the values for 'text' edit. I'll pick that slider treshold up as i want to fix another thing too.. And perhaps add all the view stuff as well in a later version.
made a small update. (1.0.6)
- more speed on the t's & r's clickdrag.
- little fix on fullreset scale when changed with 3js handles
- update bulb position after 'text' input value field.
another fix..
1.0.7
