Problem displaying layers in "flowchildren" mode when scrolling is enabled
  • Hi everyone, there is a problem in my code that I can't figure out. I have a menu, and for example, I simplified the code as much as possible. These are three blocks, the middle block has the flowexpand="true" parameter and it has scroll buttons.
    Example
    I checked on android and on PC in chrome browser
    At the first launch, it seems that the lower part becomes lower, and the lower block is not visible, and scrolling does not work correctly.
    correct: Wrong :
    The display is correct when:
    1. I am resizing the browser window
    2. I will make less than 6 panoramas on the tour
    3. When I turn off vtourskin.xml
    What could be the reason, how to fix it? *whistling*
  • Hi, on phone here.. had quick look.
    That flowchildren h .. shouldn't that be v?
    edit: had quick look at your example and for me on mac safari it seems to work just fine..
    Tuur*thumbsup*
  • klaus.krpano December 3, 2024 at 12:55 PM
    Added the label Checking
    Tuur*thumbsup*
    Hello, Tuur! the menu_container layer contains flowchildren="v" .
    The block_middle layer contains flowchildren="h" because it actually has several blocks that contain buttons and scrolling, and these blocks are shifted horizontally. I did not publish the entire code in order to focus on the essence of the problem.
  • klaus.krpano December 12, 2024 at 9:43 PM
    Set the label from Checking to Bug
    Added the label Fixed
