Is it possible to add scenes dynamically?
  • Hi, everyone.
    I'm trying to add scenes at runtime.
    I searched the forums and found similar threads and tried to do this, but it didn't work.
    I tried something like the code below:
    The log output is as follows:
    The output of debugvar(scene[0]) shows that it is set correctly in the scene.
    However, the loadscene function says that livingroom_0 does not found.
    I coded like this to solve this problem.
    Similar to the log results shown earlier, but the loadscene function does not fail.
    Is it not possible to add a scene with the set function in krpano?
    when creating a new array item by setting an item with index 0 to some values, an automatic name for the item will be created.
    The setting of the name will then actually change the name, but don't update the index/name mapping.
    Changing the name of an array item is only possible by using renamearrayitem().
    But you could do it different - direct create the scene item with the name it should have:
    set(scene[livingroom_0],
       title = 'livingroom',
       onstart = '',
       thumburl = '%VIEWER%/panos/104b_0_on/desktop/livingroom_0.tiles/thumb.jpg',
    loadscene('livingroom_0', ...);
    Or if index 0 is mandatory - first create the item (and don't set the name) and then rename it:
    set(scene[0],
       onstart = '',
    scene.renamearrayitem(get(scene[0].name), 'livingroom_0');
    loadscene(0, ...);
