Dynamic srollarea problem
    I have a problem with a scrollarea created dynamically in a container, all in another container.
    It's for a sliding and drop-down menu. I don't see the parameter(s) that cause it to crash.
    It also flickers sometimes.
    Without the scroll everything is fluid but I can't see my entire submenu with the height of the layer I chose....
    All this for the "Canal du Centre" in the end.
    Note that in the scrollarea an arrow is supposed to be clearly visible and allows you to return to the main menu. We only see a small bit of it at the top right.
    I also have trouble setting it
    The project : https://multimedia.damienlachas.com/barrage_reservoir_360/
    Layers
    Style of layers in scrollarea
    <style name="styleTitreCanal" type="text" parent="navCanal" visible="true" keep="true" zorder="100" enabled="true" alpha="1" scale="1.0" autowidth="true" padding="10"  vcenter="true" wordwrap="false" handcursor="true"  bgcapture="true" capture="true" align="topleft" edge="topleft" x="10" height="25" bg="true" bgalpha="0.0" bgborder="0"  mergedalpha="true"    onloaded="tween(alpha, 1);"
    css="font-family:Raleway; font-size:18px; text-align: left; color:0xffffff;"
    onover="set(css, font-family:Raleway; font-size:18px; text-align: left; color:0xbcff3c;);"
    onout="set(css, font-family:Raleway; font-size:18px; text-align: left; color:0xffffff; );" />
    <style name="styleListeBarrage" type="text" visible="true" keep="true" zorder="100" enabled="true" alpha="1" scale="1.0" scaley="1" autowidth="true"  padding="10"  vcenter="true" wordwrap="false" handcursor="true"  bgcapture="true" capture="true" align="topleft" edge="topleft" x="10"  height="40" bg="true" bgalpha="0.0" bgborder="0" bgroundedge="0" mergedalpha="true"  onloaded="tween(alpha, 1);"
    Function
    I hope i'am clear ... and that I have given enough elements
    Thanks for your help,
    Damien
    It seems the align="right" at the scrollarea causes the scrolling problems (although I have to admit I'm not sure yet why exactly).
    Attached here a modified interface.xml - it fixes the scrolling problems, additionally I have put a container around the scrollarea and moved the title and the return arrow outside the scrollarea:
    interface.xml
