Hello, Klaus! A great example of a dancing cat. But I can't figure out one thing: how do I just start the animation of my 3d model and control it (stop and start, or loop playback)? In the example with the cat, everything is complicated. I don't need him to move with the mouse, and when clicked, a random animation is selected. I need to make a simple action to start an animation and stop it. I can't figure out how...
ThreeJS Animation Question
- Official Post
Hi, (I have moved question here as it is a usage question and not directly related to the news post)
E.g. if your file contains an animation named 'ani1' and you want to play it on click:
or when called from somewhere else:
More information here:
krpano.com - Plugins - ThreeJS
Display More
https://krpano.com/plugins/threejs/#gltfanimations
KlausThank you, Klaus! It helped
I have a model that weighs 60mb and takes a long time to load. Is there some kind of preloader for 3d models that will show the loading process?
Best is to check the code of the Tesla example.
This probably won't work for me, because in my model all the textures are in a single glb file.
Display More
KlausThis is the model that turned out): https://panorama07.com/3d/dragon/ . There is also one more question: I did not find transparency properties in 3d models. I tried to do it as usual, but it didn't work.
- Official Post
Nice example!
A small improvement hint - try using an environment texture for the 3d-model. That helps integerating the model into the scene.
E.g. just add:
About transparency - what do you mean? -
Nice example!
E.g. just add:
https://krpano.com/plugins/threejs/#envmapurl
About transparency - what do you mean?I tried making the alpha="0" like for regular hot spots, but it didn't work for the glb model.
- Official Post
The 3D Model hotspots don't have an alpha settings defined:
krpano.com - Plugins - ThreeJSDoing alpha blending like with normal images is complicated in typical realtime 3D rendering.
The reason is that the faces/triangles would overlap and be overdrawn in an undefined order. Sorting all triangles each frame is ineffective (and would still have some problematic cases) and rendering each model into a separate framebuffer and then blending that is also ineffective.
ThreeJS has partial support for transparency, but only via Materials. When a Material has its transparent setting enabled, it will get rendered in a special way:
three.js docs -
Hi! play(loop, blendtime, playalone, callback). I can't figure out how to fit a certain number of repetitions of a single animation into this design. It is stated that it is simple: once, repeat, and pingpong. No, and so: (the number of repetitions is several, infinite by default.). The question is how to use - repetitions
i have such in an opensource barebone example here:
test
xml:
https://www.virtualtuur.com/krpano/122/barebones/examples/glb/1/tour.xmllook in the DoOnclick action.
.. to be short... use a 'counter'
Hope it helps,
Display More
https://www.virtualtuur.com/krpano/122/bar…lb/1/index.html
xml:
https://www.virtualtuur.com/krpano/122/bar…/glb/1/tour.xmllook in the DoOnclick action.
Hope it helps,
Thanks! Here's an action game that solved this issue.:
Display More<action name="DoOnclick_model2" type="js"><![CDATA[ // ========== ANIMATION SETTINGS ========== // Array defining the sequence of animations to play var animation_sequence = ["fly", "fly_right", "glide"]; // Number of repeats for each corresponding animation var repeat_counts = [3, 2, 1]; // Transition time between animations in seconds var blend_time = 0.3; // ========== SYSTEM VARIABLES ========== // Get reference to our hotspot var hs = krpano.get("hotspot[model2]"); // Index of current animation in sequence var current_animation_index = 0; // Counter for current animation repeats var current_repeat_count = 0; // ========== MAIN PLAYBACK FUNCTION ========== function playNextAnimation() { // Loop back to first animation when sequence completes if (current_animation_index >= animation_sequence.length) { current_animation_index = 0; } // Get current animation name and object var anim_name = animation_sequence[current_animation_index]; var anim = hs.animations.getItem(anim_name); // Reset repeat counter for new animation current_repeat_count = 0; // Clean up previous handler if exists if (anim.onloop) anim.onloop = null; // ===== ANIMATION LOOP HANDLER ===== anim.onloop = function() { // Increment repeat counter current_repeat_count++; // Debug output console.log("Animation " + anim_name + ", loop: " + current_repeat_count); // Check if reached required repeats if (current_repeat_count >= repeat_counts[current_animation_index]) { // Remove handler anim.onloop = null; // Move to next animation current_animation_index++; // Play next animation playNextAnimation(); } }; // ===== START ANIMATION WITH PARAMETERS ===== // 1. "repeat" - loop mode // 2. blend_time - transition duration // 3. true - stop other animations (playalone) // 4. null - no callback function anim.play("repeat", blend_time, true, null); // Log animation start console.log("Starting animation: " + anim_name); } // ========== INITIATE ANIMATION CYCLE ========== playNextAnimation(); ]]></action>
