Seems that the deeplinking function is not working from version 1.22.2 and 1.22.3.
checked on Mac, with Chrome, Safari, Firefox.
It's a pity, because is a useful function....![]()
Deeplinking function not working [solved]
- Official Post
It's working! (just tested again)
Please post a link to your not working case.
Ok, after some investigations I found that the problem happens when the webvr is set to "false":
Here webvr is set to true, and and the function "deeplinking" is working:
Here the webvr is set to false, and the function "deeplinking" is not working:
- Official Post
right, thanks for reporting!
The reason is a bug in the vtourskin.xml related to change in the webvr.xml in version 1.22.
To fix it look in the vtourskin.xml for these lines:
Code<action name="skin_deeplinking_update_url" scope="local" args="delay"> if(skin_settings.deeplinking AND (!webvr OR webvr.isenabled === false) AND global.lpinfo === null, delayedcall(skin_deeplinking_update, calc(delay == null ? 0.1 : delay), skin_deeplinking_update_url_process() ); ); </action>and change there this:
to this:
The reason in detail:- that code check if webvr is enabled to avoid constant url-updates during the vr-viewing, which might cause performance problems,
- since version 1.22, the webvr plugin is included using the new plugin api setting - and with this the 'webvr' object gets predefined already when defining the plugin,
- therefore the !webvr check fails, it previous version that worked because there the 'webvr' object gets defined when the webvr plugin has finished loading,
- and because the webvr plugin isn't loaded, its isenabled setting is not defined and therefore the explicit check for === false fails.
The fix will be also included in the next releases of course.Best regards,
Version 1.22.4 has resolved the problem,
thank you Klaus!
tonesh
April 10, 2025 at 8:58 AM Changed the title of the thread from “Deeplinking function not working” to “Deeplinking function not working [solved]”.
