[SOLVED] ISSUE Krpano Tools 1.2.2.4 -> Protect Tool -> Generate Viewer
  • Hi, Klaus when I try to generate a viewer (tour.js) with the first option "Allow loading only private-key encrypted xml and plugin files" it create the tour.js which give the following error to run index.html: "FATAL ERROR:tour.xml - loading failed! decoding error"
    Please, I need your help to solve this *confused*
    Edited once, last by Fernando (March 9, 2025 at 2:59 PM).
  • Hi Klaus, thanks for your quick reply.
    I'm pretty sure I used PRIVATE and not PUBLIC. Could you please check that it's not a krpano tools error?
    I can make a video illustrating the whole process. By the way, is it necessary to encrypt the plugins folder and the tour.js file? I did it that way and I can reproduce everything in the video.
    Fdo
  • By the way, is it necessary to encrypt the plugins folder and the tour.js file?
    The tour.js is the krpano viewer, when it will be encrypted, the browser will be not able to load it *wink*.
    That means don't encrypt that file.
    When the setting 'Allow loading only private-key encrypted xml and plugin files' is enabled, then the plugins need to be encrypted as well. The encrypt tool therefore supports making public-encrypted files (like many krpano plugins) to private-encrypted ones by re-encrypting them.
  • Fernando March 9, 2025 at 2:44 PM
    Changed the title of the thread from “ISSUE Krpano Tools 1.2.2.4 -> Protect Tool -> Generate Viewer” to “[SOLVED]ISSUE Krpano Tools 1.2.2.4 -> Protect Tool -> Generate Viewer”.
  • Hi Klaus, thanks to your help I ruled out any problems related to krpano. *thumbsup*
    The solution was
    1) clean the Windows registry with regedit
    2) remove registration -> register again
    3)restore defaults of krpano tools.
    Fernando
  • Fernando March 9, 2025 at 3:00 PM
    Changed the title of the thread from “[SOLVED]ISSUE Krpano Tools 1.2.2.4 -> Protect Tool -> Generate Viewer” to “[SOLVED] ISSUE Krpano Tools 1.2.2.4 -> Protect Tool -> Generate Viewer”.
