Is it possible to dynamically inject <depthmap> into panorama scenes at runtime?
  • Hi Klaus and krpano community,
    I'm trying to dynamically inject <depthmap> definitions into my panorama scenes at runtime, but the mesh doesn't load.
    krpano 1.22.2 (build 2024-11-20)
    What I'm doing:
    • I build the krpano XML dynamically. Inside the <scene> → <image> tag, I include a $DEPTHMAP placeholder.
    • Then I create a pano object and call .kr.embedpano(pano).
    • Once onready is triggered, I initialize my custom plugins.
    If the current panorama requires the Measurements Plugin, I:
    1. Get the original XML from the krpano instance via krpano.xml.filecontent.
    2. Replace $DEPTHMAP with a fully-formed <depthmap>...</depthmap> tag.
    3. Then I reload krpano via:
    krpano.call("loadxml(newXml, null, REMOVESCENES)");
    krpano.call("loadscene(sceneName, null, BLEND(0))");
    ❗ The issue:
    The scene visually reloads, but the mesh files (.mesh) are never requested — nothing appears in the network tab, and no depth-based rendering happens.
    ✅ What works:
    If I include the <depthmap> in the XML before calling .kr.embedpano(pano), everything works perfectly — the mesh loads and renders correctly.
    What I’ve tried:
    • Switching between MERGE|KEEPVIEW, REMOVESCENES, or no flags with loadxml().
    • Calling loadscene() immediately afterward.
    • Inspecting krpano.get('scene[sceneName].depthmap.src'), which returns undefined.
    ❓ My question:
    What is the correct way to dynamically inject or update <depthmap> definitions at runtime and force krpano to actually load the mesh?
    Thanks in advance — I’d really appreciate any guidance *smile*.
    Edited once, last by Volodymyr_vHive: added krpano version that I use (April 22, 2025 at 11:40 AM).
