How to using depthmap texture modal for multiple pano images
  • Hi all, i'm reading an example about depthmap texture model https://krpano.com/viewsource.htm…xtured/test.xml
    In this example just have 1 image. I have a obj modal rendered from 3 pano images, I don't know how to apply for multiple images (is all pano images usingthe same obj file ?). Please help me!
    I'm not fully sure what you mean, but you can multiple panos with the same obj model. The model will be automatically loaded only once.
    The aligning the pano inside the model, the depthmap origin and align settings can be used:
    krpano.com - Documentation - XML Reference
    Although doing that alignment manually can be a bit tricky. There will be a helper tool for that in one of the next releases.
