I have still problems to understand the correct handling of passQueryParameters
  • In my panos I pass a variable 'design' to distinguish betweeen mobile or desktop applications, for example:
    <include url="../skins/d_skin.xml" if="design == default_" />
    <include url="../skins/m_skin.xml" if="design == mobil_" />
    In either case the special skin for mobile or desktop will be selected
    In order to pass the variable 'design' the index.html looks like this:
       <script>embedpano({xml:"example.xml", target:"pano", initvars:{design:"default_" }, passQueryParameters:true}); </script>
    or
       <script>embedpano({xml:"example.xml", target:"pano", initvars:{design:"mobile_" }, passQueryParameters:true}); </script>
    This works properly! But I want to get rid of passQueryParameters:true
    If I set passQueryParameters:false the pano will not start at all. This I can still understand.
    But if the code is for example like
        <script>embedpano({xml:"example.xml", target:"pano", initvars:{design:"mobile_" } }); </script>
    as shown in the documentation the pano does also not start!
    Can anybody tell me, what do I wrong or what is the solution ?
    I currently use krpano 1.22.2
    my homepage: foto180.de
  • Hi Klaus,
    thank you for your instant message after midnight.
    I tried it immediatelly, but it does not work. Opening the pano, the screen gets white, nothing happens. *question**question*
    What would be different switching to 1.22.4 ?
    Regards, Ewald
  • II am sorry, I do not know, how to show you a link
    I can only show you the original code with the recommended correction:
    <script>
    embedpano({xml:"kirchen_de.xml", target:"pano", initvars:{backhtml:"v2", design:"default_", org:"kirchen_" }, passQueryParameters:"backhtml,design,org"});
    </script>
    Maybe, you can verify it, looking at my website: foto180.de
    go to '360 Grad Panoramen' --> 'Kirchen' --> 'Deutschland'
    all of the about 150 churches depend on this code.
    I have an Idea: I modify my webpage for this afternoon: Churches Germany get the modified code, Churches France keep the old code, so you can see the difference.
    I do not have a better Idea.
    But thanks a lot for your excellent service
  • Hi, midnight worker!
    Problem solved! I forgot 'startpano'
    I added 'startpano' to the passQueryParameters list: passQueryParameters:"startpano,backhtml,design"
    NO 'true' anymore!
    My experience: in most cases not the code is the problem. The problem is sitting between the left and the right ear.*smile*
    Many thanks, Klaus
