How to disable keepview when using 3dtransition?
Skin_settings has attribute loadscene_flags="MERGE"
Hotspot has attribute use3dtransition="true" and after clicking pano changes default view.
Hlookat and vlookat default values of target pano must be used.
How to do it?
Disabling keepview when using 3dtransition
Richard777
July 4, 2025 at 10:47 PM Changed the title of the thread from “Disabling keepview with 3dtransition” to “Disabling keepview when using 3dtransition”. -
any ideas, please...
keepview is possible with 3dtransition, the problem must be somewhere else
Did you try to use the hlookatoffset?
krpano.com - Documentation - Actions / Scripting Reference
Tuur -
I want to use 3dtransition without 'keepview' function.
I.e. I don't want to keep the current/previous viewing settings.
Each pano has its own settings and only they should be used, is it possible to turn off 'keepview'?
I hope it is understandable.Thanks.
Hi, I think 3dTransition is designed to create a transition effect as if you were walking from one place to another. The final viewpoint (for example, the one that comes by default with the scene) can be defined with hlookatoffset, but it no longer looks as if you were walking to that place. Perhaps you could use 3dTransition and then, with a separate action, change the view to the one that comes by default with the scene. In short, I don't think it's possible to disable keepview in 3dTransition.
