Help: Popup example enhanced (zoom/pan image)
    The image popup example is still a good and efficient solution. The only thing missing would be the ability to zoom and pan images (.jpg as HTML img label). I don't think there's a specific need, or perhaps just limiting the zoom to 100%.
    Has anyone come up with a solution using JS, HTML5, and CSS that completes the image popup in krpano's example?
    If not, would you consider working together to find a solution? *smile*
    Fdo.
  • Hi, I think a good solution would be to create an iframe with a flat, multi-res krpano project.
    By the way...-How to make a transparent background for this krpano iframe inside the div?
    Fdo
    Edited once, last by Fernando: new solution (September 17, 2025 at 4:58 PM).
