please see this test case:
krpano
What I see, when I open this link:
https://36o.de/test/krpano-1.23.2-2025-09-22-krpanomaps/screenshot.jpg
There are several blurred areas on the OSM map that are not loaded properly. The missing tiles are loaded when I zoom the map.
The test case is based on your krpano Maps Plugin example. You can download the altered example code here:
https://36o.de/test/krpano-1.23.2-2025-09-22-krpanomaps/code.zip
Can you please check, if this can be fixed for the next release?
Kind regards
Christian
