ERROR UPLOAD Gigamacro with krpano 1.23.3 and flat.config
  • Technical Question for Support
    I am attempting to upload a multi-resolution flat panorama generated with krpanotools 1.23.3 (using flat.config, tilesize=512) but I consistently receive the error 'Error when processing upload' after submitting the ZIP file.
    I have already verified the following:
    1. ZIP Structure: The archive contains only the pano.xml file and the tile folder (named tiles) at the root level.
    2. Minimalist XML: The pano.xml file has been stripped down and contains only the <image> tag with the flat url and multires data. All <include> and <preview> tags have been removed.
    3. Encoding: The pano.xml file is correctly encoded in UTF-8 (without BOM).
    4. Image Size: The source image size is 25330x7917 pixels.
    Command Executed: krpanotools makepano -config=templates/flat.config [FILENAME].jpg
    The XML Content: <krpano>
    <image hfov="1.00" vfov="0.312554" voffset="0.00">
    <flat url="HDR_Panorama_Brisighella_Via_Siepi_400mm_19_11_2025_HD.jpg/tiles/l%l/%0v/l%l_%0v_%0h.jpg" multires="512,1536x480,3200x1000,6400x2002,12800x4002,25344x7922" />
    My question is: What are the specific XML validation requirements for your parser? Is there a mandatory tag (e.g., a <scene> tag or a specific attribute) that must be present, or does the XML file need to be generated from a specific template that differs from the standard krpano flat.config output?
    Best regards
    Paolo
