Issue with aliasing on non-Android, non-iPhone device
  • Hi all, I have a device that is neither Android nor iPhone. On this device, when using krpano to display panoramic images—whether in a WebView or a browser—there is a serious aliasing (jagged edge) issue. However, when I set the WebView’s user agent to "Android", the aliasing disappears and the panorama becomes very sharp and clear.
    Unfortunately, I cannot change the user agent for the browser. My question is: Is there any way to eliminate aliasing by adjusting krpano parameters? If so, which parameters should I set?
    I have tried setting display.antialias=true and webglsettings.antialias=true, but neither seems to have any effect.
    what device is this?
    But setting the webglsettings embedding should definitely work:
    krpano.com - Documentation - Embedding into HTML
    How do you set it?
    Correct would be in the embedpano call:
    embedpano({..., webglsettings:{antialias:true}});
    But even with disabled anti-aliasing, there should be no jagged edges in the pano images, the anti-aliasing mainly only effects hotspots edges... So maybe the actual problem is something else...
  • Thank you for your reply. I did follow the documentation to add the WebGL settings, exactly as you wrote in your reply, but unfortunately, they still didn’t work.
    The device I’m developing on is a Huawei phone running the HarmonyOS system. The WebView’s user agent is:
    Mozilla/5.0 (Phone; OpenHarmony 6.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.
  • index.html
    test.xml
    Before appending the "android" string to the WebView's User Agent:
    After appending the "android" string to the WebView's User Agent
    this is not anti-aliasing, this is wrong (too low) rendering resolution...
    In krpano there is a detection and workaround for very old Android devices that weren't handling HiDPI cases (devicePixelRatio > 1.0) correctly, and it seems your device is somehow getting into this case...
    Will check that further, I think that special case handling can be already removed...
