ios/iphone issue using weird scaling tour
  • Hi all
    i have a task of digitizing a leaflet and it will be shown in a 9:16 leaflet style screen
    all is working in desktop chrome and android chrome ( i have not tested others)
    images are 4500x800 and krpano produces html like so
            <view hlookat="0.0" vlookat="0.0" fovtype="MFOV" fov="120" maxpixelzoom="2.0" fovmin="70" fovmax="140" limitview="auto" />
            <image hfov="1.00" vfov="1.777778" voffset="0.00">
    as you can see they are very tight fov values
    I showed it to a friend and he said he could not view the text in iOS and while investigating it in pc emulator i noticed all the text shows in topleft with the appeareance i need but with wronc scale
    my text style is like so ->
    <style name="mytextstyle" translate="true"  type="text" distorted="true" scale="0.01"  edge="lefttop" renderer="auto" textalign="lefttop" align="lefttop" bg="false"  bgborder="false" autoalpha="true" alpha="1" enabled="true" capture="false" width="75%"/>
    if i change the scale to 1 then text shows up but at wrong places. When i go to see the bottom of the page all text hotspots move up but text moves up at a fraction of the speed.
    i got two image hotspots and they show in place and move accordingly so it seems it is only text and in iOS.
    attached : a screenshot of the same area in desktop and in playwright webkit emulator
    plugins up to date
    krpano 1.24 25-06-2026 but it happened in the previous version too
    i'd really appreciate some help so i could avoid making a new tour only for ios
    thnk you all
  • hHi again,
    Here is a demonstration
    if you do not open in chrome and scroll to the top in ladscape you'll see the text distorted hotspot with lots of AAAAAAA and if you scroll down you'll see 2 graphics for the language choice
    if you open on android you'll see the whole page with lots of AAAAAA
    if you open on iOS you'll get the language choice in the bottom but you'll neet a maginifyer to see all the AAAAAA in the top left
    text on iOS krpano
    any clues ?
    Thank you all
