Best way to detect and switch layers and styles if webvr is enabled
    I would like to make dynamically certain styles and layers active, when webvr is used or faked.
    In my example I want to use hotspots for tooltips if webvr is enabled or faked
    and use layers for tooltips in all other conditions.
    If possible I would like to keep the original webvr events and procedures and to only add if necessary an own <action>.
    Here are my styles (defined in vtourskin.xml):
    What is the best way to do the switch?
    Can I check dynamically (during runtime) within the <style>, wheter webvr is enabled or faked?
    All my tries failed so far. I would appreciate help for this topic. If possible without changing webvr events and procedures.
    Is there a difference to switch in <styles> and <Layers>?
    Edited once, last by Tester 17 (August 4, 2026 at 1:01 PM).
