Tuur's example works above but it is using 1.0.8.11 not 12.
iphone, please check and comment..
more coming up
For me, this example does not work (well it "works", but the navigation is lost, which is the same problem I'm having.)
Here are the steps to recreate the issue with the example above:
- Use Safari 5.0.2 with User Agent set to iPad
- Choose the top-left option (Aspen)
- Choose the left-most little world button (although, they all have the same problem)
- The pano will jump out of the frame and cover the navigation
Hilf mir bitte...
forget my example and try this one..
http://www.virtualtuur.com/enk/3/
but this is just a play..
you have to think if you want a menu bar etc on the phone.. (don't have one yet..)
This one is different on iphone as it is on desktop..
try and error i should say..
Thanks Tuur. That's a good example, but I still would like to have a navigation frame that stays in place, while the pano loads in the larger frame. I will continue to torture myself trying to fix it.
maybe fix your second /large frame. so rthere is space for tyhe iphone navigation if that is what you mean..??
good luck
OT: Is the picture shot on a street crossing Prinsengracht? I used to work in an office on Keizersgracht and this looks familiar.
yes but not shot by me..
