• Hi Klaus,
    just one question. I am using the same xml for iPad and Flash, and for the same FOV the iPad pano view is closer than the Flash pano at the same size of viewport.
    For instance, with a FOV of 90 I have a good view on iPad, but a bit far for the flash view. I think that 90 FOV of iPad is aproximately 75 FOV for flash. If I select a 75 FOV is good for my flash pano, but a bit blurred for iPad.
    Is possible to enhance this tip?
    Also, one detail more but less important. In kmakemultires.config to allow not to copy iphone license as copyswf.
    Thanks, and very good work *thumbsup*
    best regards
    in the Flash viewer the default fovtype is VFOV (=vertical fov),
    that means the fov is based on the screen height,
    but on the iPhone/iPad where the screen can be rotated, a fov based on the screen height is not optimal,
    the view/fov will change too much very when rotating,
    so I have used the 'MFOV' as default fovtype there (not changeable at the moment but soon),
    when you set in the XML:
    <view ... fovtype="MFOV" ... />
    then you have the same fov in both viewers,
