A new Sound Plugin - soundinterface.swf
- this plugin adds functions to play and controls sounds direct from the xml.
- only this one plugin must be loaded for all sound.
- note - the functions are not available until the plugin was loaded use the plugin onloaded event or the preload="true" plugin setting to verify that!
Download latest plugin version:
Included in the latest krpano viewer download package
Examples:
Directional Sound
Usage:
<plugin name="soundinterface"
url="soundinterface.swf"
rootpath="."
Attributes:
- onloaded
- this action is called when the plugin was loaded and is ready for use.
- can be used for preloading sound.
- rootpath
- root path of the sound files
- relative from the xml file, default=""
- with krpano 1.0.8 or higher it's possible to use placeholders like %SWFPATH% here
- volume
- set the global volume for all sounds
- 0.0 - 1.0, default=1.0
- can be changed dynamically via actions (set/tween/...)
- mute
- set the global mute for all sounds
- true or false, default=false
- can be changed dynamically via actions (set/switch/...)
Functions:
- preloadsound(mp3file);
- preloads a sound file
- this can be used to reduce the latency when starting play
- mp3file = the filename/path of a sound file
- playsound(id, mp3file, loops*, oncomplete*);
- plays a sound file
- id = id/name of the sound (use "auto" for a automatic new id for every play)
- loops = number of loops, 0=endless, default=1 (*optional)
- oncomplete = action/event that will called on complete (*optional)
- playsound2D(id, mp3file, volume*, pan*, loops*, oncomplete*);
- plays a sound file with adjustable volume and panning
- volume = sound volume (0.0 - 1.0, default=1.0) (*optional)
- pan = left/right panning (-1.0(=left) - +1.0(=right), default=0.0) (*optional)
- playsound3D(id, mp3file, ath, atv, range*, volume*, loops*, oncomplete*);
- plays a directional 3D sound
- ath = horizontal sound source position (-180 .. 180°)
- atv = vertical sound source position (-90 .. +90°)
- range = range of sound (in degrees, default=90) (*optional)
- playsound3DHS(id, mp3file, hotspotname, range*, volume*, loops*, oncomplete*);
- plays a directional 3D sound at a hotspot position
- it follows the hotspot if the hotspot is moving
- hotspotname = name of the hotspot
- pausesound(id);- pauses a sound
- resumesound(id);- resumes a paused sound
- pausesoundtoggle(id);- pauses OR resumes a sound
- stopsound(id);- stops playing a sound
- stopallsounds();
- stop all current playing sounds
XML usage example:
<plugin name=soundinterface"
rootpath="sounds/"
<hotspot name="s1" url="spot.png"
onclick="playsound(auto,tada.mp3);"
onover="playsound(auto,over.mp3);"
onout="playsound(auto,out.mp3);"
<hotspot name="s2" url="spot.png"
onclick="stopallsounds();
loadpano(next.xml,null,MERGE,BLEND(1));
playsound(auto,newsound.mp3);"
Display More
