I downloaded the demo of krpano to test it. My question is how should I provide the panorama to my clients for offline viewing? If I'm not mistaking I noticed that along with the swf file there need to be also present some other files too like XML and JS files for the panorama to work. This will be confusing for some people not very familiar with computers. Additionaly, they would have to have Flash Player which, again, if the client is not very familiar with computers might not have and know how to install. Is there a way to create a single EXE file for example so everybody, not only those who have flash player could view the panorama? Or some fool-proof method for cases like this?
Providing a panorama to a client. How?
Krpotect can create an .exe and also an app for the Apple folks. You must have a license to use that program though so you would not be able to test it, (at least I don't think you can).
How much does krprotect cost? Is this an add-on that I have to buy separately from krpano or it comes with it?
It's inside Krpanotools
It is included (no additional charge over standard licensing) and is in the download package. I just think it requires a license to function.
Thanks, I think this answers my questions.
Hi all,
Jarredja
(and many others as myself
) . Testing the viewer and tools is possible also without license:Display MoreThe viewer and the tools can be download and tested for free!
They are fully functional, but there are some restrictions without license:krpano Flash Panorama Viewer
• it runs only offline/locally or on a localhost server
• it shows a demo watermark in the middle of the screenkrpano Tools
• they generate random watermarks in the output-images
• and show a short waiting time after image processingFor unrestricted usage a license must be purchased.
More informations here on the Buy site.so,
Yes... For example:
- drag an drop your pano image above the MAKE PANO (NORMAL) droplet.bat
- the droplet generates, inside the same folder as your original pano image, all the files needed to see your pano (in particular the xml file)
- open the kprotect.exe
- select output format as Standalone Windows (.exe)
- browse to select the xml file generated above
- Press Generate Protected File
- Save ... That's all... you got your single EXE file that have all the needed to be viewed...
Hope this help...SAlut.
