We're using kmakemultires (part of release 1.0.8.11) to automatically convert uploaded images from our customers to a multi-resolution set. Depending on the dimensions of the input image we assume a certain output. It has always been to my understanding that with an exact width/height ratio of 2:1 that we can safely assume images for cubical projection can and will be outputted. If it's anything above 2:1 (say 3:1) than we have to assume we're dealing with a partial (vertical wise) panorama and output images for spherical projection.
However, in our testing we see this logic is not completely followed by kmakemultires. It almost seems as if kmakemultires has a margin of error in determining for how long it will still try to output cubical images.
We assumed:
- 2000x1000 (2:1) --> cubical
- 2001x1000 (>2:1) --> spherical
- 3000x1000 (>2:1) --> spherical
However, the following seems true:
- 2000x1000 --> cubical
- 3768x1880 (>2:1) --> cubical (real world example)
We have not yet determined the boundary, as I'm kind of hoping someone can share the algorithm so we can explain it to our customers and make adjustments accordingly.
