Quality settings for Lookto movements
  • I have been using lookto for creating an autotour which works both on flash and HTML5.
    I found that the quality during movements is much decreased compared to autorotation especially on my iPad.
    I can not find any way to control the quality during these movements.
    Hans
  • Have you tried linear instead of smooth? I don't know if it will fix your problem but it might be worth a try.
    Found under lookto:
    •motiontype (optionally)
    The type of the motion.
    Possible settings:
    ◦linear(speed) - a linear motion
    ■speed = moving speed in degrees/second
    ◦smooth(accel,break,maxspeed) - accelerated smooth movement (=default)
    ■accel = acceleration in degrees/second² (default=720)
    ■break = negative acceleration in degrees/second² (default=-720)
    ■maxspeed = maximum moving speed in degrees/second (default=720)
