Using 'converttocube', but still spheres are generated
  • Hello,
    I'm using the kmakemultires tool with the option converttocube=true specified in the config-file. However, in the xml that is generated I still get the attribute type="SPHERE" in the <image>-tag. And indeed, there doesn't seem to have been a sphere-to-cube conversion at all. The source panorama file is a partial sphere (360x*). Even if I specify panotype=partialsphere in the config file, there's no conversion to a cubical panorama.
    Does anyone have an idea what I could be doing wrong?
    Thanks,
    Bob
    converting partials to cube and setting the view limits automatically is already possible,
    see the "converttocubelimit" setting in the .config files:
    # converttocubelimit
    # - convert also 'partial' spherical (360x*) images to cubical ones
    # - set the range what a partial pano need to achieve to be converted
    # - works only when "converttocube" was set to true
    converttocubelimit=360x120
  • Thanks, it works very well now!
    The problem was that I didn't completely understand how 'converttocubelimit' worked.
    Correct me if I'm wrong, but I understand that with this option, you must specify the minimum vof-range that the source image needs to have to allow the conversion of a partial sphere to a partial cube.
    If I set it to 360x1, practically all partial spheres will be be converted.
  • Quote
    right!
    but note - for very small/narrow partials (e.g. 360x10) you may waste a lot memory in this case...
    when viewing - all the black pixels (out of the pano range) are still there in the computer memory, 1 pixel is ~4byte in memory,
    the jpeg may be small, because large single colored areas can be compressed very good, but when viewing the image is decoded into pixels of course,
