How to pass an instruction via js() with commas?
  • I have a JS() inside an xml and its html contained in an iframe inside the parent html.
    This works in the parent html:
    <a onclick="loadscene('scene_87, null, MERGE, BLEND(1), set(plugin[map].visible, false);');">
    but this in the xml within the iframe only works , but only the first parameter , it works up to the first comma:
    <hotspot name="capilla"  style="hotspot_over"
    		onclick="js(parent.loadscene(scene_09, null, MERGE, BLEND(1)); setmask(mask_capilla, 0,560,297);)" >
    		<point ath=" 0.069376" atv="-0.089533" />
    loadscene(scene_09, the rest does not work! I assume its because of the comma?
    how do I pass all the required actions ?
    tried " or ' and it does not work
    the function in the html is:
    function loadscene(scene)
      		krpano().call("loadscene(" + scene + ");");
    any clue on how to solve this?
  • HI,
    Sorry for popping out here, but it seems like a best place for my question.
    Lets say I have an variable which I need to pass to js. This variable contains an xml string (with encoded <, > and so on) and some of the attibutes has a text with commas.
    Unfortunatelly, the krpano handles this and send it as a separate variables to the js function.
    How can I avoid splitting string to separate variables?
    Here is n example:
    xml:
    set(functionCall, "myJsFunction('&gt;text=&quot;hello, world!&quot;&lt;')");
    js(functionCall);
    js:
    var myJsFunction = function(param) {
    alert(param);
    expected: alert with '<text="hello, world!"> text
    actual: alert with '<text="hello' text
